Guide to calculating over/under in football: Count the total number of goals scored in the match and compare it with the placed bet to determine a win or loss against the bookmaker.
In an era where online betting is increasingly popular, understanding and applying the daily record football tips of calculating over/under in football can help players participate more confidently. Let's follow this article to learn how to play over/under football betting in detail from A to Z for beginners in a simple and easy way.
What is over/under betting in football? Principles of calculating over/under in football
Over/under betting in football, abbreviated as O/U, is a common type of bet in football offered by bookmakers. In the principle of calculating over/under in football, the bookmaker will provide a predicted number for the football match. The player's task is to bet on that number, and the player will have two main choices as follows:
Over: This is when the total number of goals in the match exceeds the odds ratio provided by the bookmaker.
Under: This is when the total number of goals in the match is less than the odds ratio provided by the bookmaker.
Draw: If the total number of goals matches the odds ratio, the result will be a draw.
Currently, bookmakers often use over/under odds for many different types of events, such as the total number of goals, the total number of points in a basketball game, the total number of fouls, and the total number of corners in football. This brings diversity and attractiveness for players participating in betting.
12 Ways to accurately calculate over/under in football according to specific betting odds
How to calculate over/under in football is currently a topic of interest and wide discussion on many different forums. Below, top experts will reveal details about the information related to calculating over/under in football. Let's explore useful information about football betting below!
#1. Over/under 0.5
If the total number of goals in the match is greater than 0.5, the Over bet will win, and the Under bet will lose.
If the total number of goals in the match is less than 0.5, the Over bet will lose, and the Under bet will win.
#2. Over/under 0.5/1
If the total number of goals in the match is 2 or more, the Over bet wins and the Under bet loses.
If the total number of goals in the match is less than 1, the Under bet wins and the Over bet loses.
If the total number of goals is 1, the Over bet wins half of the wagered amount, and the Under bet loses half of the wagered amount.
#3. Over/under 1
If the total number of goals in the match is 2 or more, the Over bet wins, and the Under bet loses.
If the total number of goals in the match is less than 1, the Over bet loses, and the Under bet wins.
If the total number of goals is 1, both bets are a draw.
#4. Over/under 1/1.5
If the total number of goals is 1, the Over bet loses half of the wagered amount, and the Under bet wins half of the wagered amount.
What is a football tip? See now : what is an asian handicap in soccer
#5. Over/Under 1.5 goals
If the total number of goals scored in the match is 2 or more, the over bet wins, and the under bet loses.
If the total number of goals scored in the match is less than or equal to 1, the over bet loses, and the under bet wins.
#6. Over/Under 1.5/2 goals
If the total number of goals scored in the match is 3 or more, the over bet wins, and the under bet loses.
If the total number of goals scored in the match is 2, the over bet wins half the stake, and the under bet loses half the stake.
#7. Over/Under 2 goals
If the total number of goals scored in the match is 2, both bets are a push.
#8. Over/Under 2/2.5 goals
If the total number of goals scored in the match is 2, the over bet loses half the stake, and the under bet wins half the stake.
#9. Over/Under 2.5 goals
If the total number of goals scored in the match is less than or equal to 2, the over bet loses, and the under bet wins.
#10. Over/Under 2.5/3 goals
If the total number of goals scored in the match is 4 or more, the over bet wins, and the under bet loses.
#11. Over/Under 3 goals
If the total number of goals scored in the match is 3, both bets are a push.
#12. Over/Under 3/3.5 goals
If the total number of goals scored in the match is 3, the over bet loses half the stake, and the under bet wins half the stake.
Does over/under betting include extra time?
When participating in betting on football matches, aside from understanding how over/under betting works, a common question among bettors is whether over/under bets apply to extra time. This uncertainty can influence betting decisions. Below, we'll delve into the specifics of whether over/under bets include extra time.
Most bookmakers may apply over/under bets to both regular playing time and extra time in a football match. However, this can vary depending on each specific bookmaker. If a bookmaker allows over/under bets to apply to extra time, the regulations will be similar to those for regular playing time. The total number of goals scored will be counted during extra time and compared to the odds set by the bookmaker.
Conclusion
With all the information betting tips app download shared here, you should now have a clear understanding of how over/under betting works in football, right? Don't forget to regularly follow the latest articles on our website to stay updated on the most interesting information.
How to calculate over/under in football betting simply and accurately
- Мотоцикл: x1
