One thing that may be news to many people: there are different types of gold found in nature! Understanding the existence of each of these ores is fundamental for those who work in this area.
Each type that exists has a direct special data impact on the value that a piece that uses this material can add. And yet, when we look at colors, these differences are also extremely impactful.
Do you know each of these types? If not, by reading this article you will understand the main points that can be used to distinguish the composition of the gold that makes up your jewelry. Let's go!?
How to differentiate between types of gold?
First of all, we need to understand how the types of gold begin to differentiate. To do this, let's look at the chemistry bias. Where each one differs is in terms of gold content.
In other words, the percentage of raw material in its composition . The purer it is, the higher its percentage of purity — or, in the case of this material, the kilometer . Basically, think that a certain type of gold is 60% pure.
In this example, while the raw material is mostly gold, the other 40% is made up of different types of materials. In this sense, the purer it is, the greater the added value.
What are the main types of gold?
To start making this differentiation, see that to be considered a material of great value, it needs to be pure . And it is precisely because of this that there are variations in jewelry prices.
Furthermore, the greater its purity, the lower the chances of oxidation. In this sense, a piece can last a long time when it contains a large amount of gold.
But let's get to know the main types, how they are applied and their respective colors:
Yellow Gold
Without a shadow of a doubt, the main and most common type on the market. Composed of more than 75% gold, 15% silver and 10% copper, it is used in traditional pieces such as rings, wedding rings , bracelets, chains, necklaces, among others.
White Cholocate bonbon
Very aimed at the female audience, such as rings and necklaces, this type of piece also contains 75% gold. However, the 25% palladium and silver enrich its visibility, thus being, in the vast majority of cases, more valuable than the traditional model, mentioned in the item above.
Rose Gold
For those looking for delicacy in their pieces, know that rose gold is one of the best options among the types on the market. Largely aimed at the luxury jewelry market, it contains 75% gold, 23% copper and 2% silver.
Black Gold
Yes, it is a rarity. Composed of 75% gold and 25% cobalt, they are less easily found on the market. However, pieces that use this raw material are considered the most valued on the market.
In conclusion, there are many other types of gold — such as green and red, each with its own application and color, as well as, of course, its purity.
Remembering that for semi-jewelry and jewelry reseller operations, it is essential to know the source of the pieces used.
